peteytesting's avatar
Oct 05, 2016
hidden features
hi guys
just incase you havnt found it yet there is a hidden page
to access
https://192.168.1.1/debug.htm
one feature you will find there is an advanced attached device list that will help see what devices are connect to the router or sat and what band they are connected to
pete
  • note:
    if you have the ip address of your orbi replace 192.168.1.1 with the gateway address you have set on the orbi
    pete
  • How do you access the attached devices list that shows what band they are attached to?
    • TheJedi's avatar
      TheJedi
      The link is dead, can you re-post? I'm coming from ASUS routers and it's been extremely tough getting used to this very limited very basic user interface. The features I'm looking for the most are the ability to see which device is using up my bandwidth and also what the signal strength is of every device. If anyone finds this please post.
        to have that level of monitoring you are best to use your asus as a router and the orbi in AP mode and get the best of both worlds
  • It does do something. It shows which WIFI band the client connects to.
