jasondunn
May 26, 2021Apprentice
Hide SSID option removed from RBR50 firmware 2.7.2.104
I need to temporarily hide the SSID of my 5Ghz network, but the option to do so appears to have been removed. I'm under Advanced > Setup > Wireless Setup. Wasn't it here previously? Did they move it someplace else?
You want the Wireless Setup under "Advanced Setup" at the bottom of the menu.
jasondunn wrote:I need to temporarily hide the SSID of my 5Ghz network, but the option to do so appears to have been removed. I'm under Advanced > Setup > Wireless Setup. Wasn't it here previously? Did they move it someplace else?
That is indeed where it is. (see attached image)
p.s. Images that are included "in-line" using the Photos icon in the menu bar do not appear to other users until they are approved by a forum moderator. There are not many moderators, so this can take hours (or days?)
Images that are "attached" using the Browse... button below are visible immediately.
- jasondunnApprentice
I appreciate the fast response, but mine looks nothing like yours - hence my confusion, and that's why I posted here. So if I'm on the latest firmware (2.7.2.104) and I have none of those options - in fact it's IDENTICAL to the basic wireless settings - what do I do?
What browser are you using? Try a different browser?
