Gellie
Jan 25, 2020Aspirant
HiRez music streaming problem
So in the last day or so ive been having intermitent problems streaming HiRez music from my Squeezbox touch. I have been experiancing buffering problems. The folks on the Squeezbox forms insist its a WiFi Issue. I have the routers in AP mode. I have changed the 2.4ghz channel , and it seemed to have work for a hour or so. Mind you this is the only device i am have any trouble with. I am using a Fios router thats about 6 months old. Are there any settings i should check/change before performing hard resets on the Fios/Orbi? I have already unpugged everything and repluuged it on. Unfortunatly i can not hard wire into the router. TIA
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).Has a factory reset and setup from scratch been performed since last FW update?
- GellieAspirant
Thanks. How do I perform a factory reset and setup?
Two ways, by entering the RBRs web page and selecting ERASE under Administration/Backup Settings or by pressing the reset button in back of the RBR/RBS for 15 seconds then release. Walk thru the setup wizard and be sure to write down important information for safe keeping.
