Rioo
Jun 03, 2022Guide
HomeKit Router Support for Netgear Orbi
To the Netgear Support Team, When will you integrate Apple HomeKit Router on the Orbi and Nighthawk systems? It's pretty sad that other vendors like Linksys and Amazon have been able to do this ...
Jun 03, 2022Guru - Experienced User
What Orbi model do you have?
Be sure your posting in the right section of the forums for Orbi products.
Something to post about here:
https://community.netgear.com/t5/Idea-Exchange-For-Home/idb-p/idea-exchange-for-home
Rioo
Jun 03, 2022Guide
Hi,
Thanks for the response, I have an RBR20.
That thread you directed me towards basically proves the point that Netgear doesn't even listen to the customer and has 300+ ideas to at least consider/implement.
So what's the point in posting in the, "right section" if the actual support team isn't even addressing anyone?
This is no attack on you as I see you're trying to help, but rather a question about what consumers should do to be heard and listened to? Should we mail in letters or contact the engineering team directly? No one wants to spent $300+ and then not have any features implemented.
- FURRYe38Jun 03, 2022Guru - Experienced User
You can look thru this and see if there is anything that is helpful:
Orbi and Homekit has been problematic over the years. Not sure if NG will ever fix it.
Something to post in the right section as if you don't NG won't know.
