globespy
Jul 18, 2018Apprentice
Horrible Performance issues with Multi-users - no it's not my Internet connection
My 12 year old is here on vacation staying with me.
We decided to play Xbox last night, she was wifi connection (likely connected to the upstairs 2nd satellite), I'm hardwired to the main router un...
Jul 18, 2018Guru - Experienced User
You can review this and see if he helps you:
I set this up for my friend who has 3 xbox consoles, two are gamers, one is a streamer.
I have two xbox consoles on my system. Zero issues with gaming or XBL chat. We both game with the friend mentioned above and with others. Gaming and Chat works for us.
- globespyJul 18, 2018Apprentice
Thanks very much for the reply!
I will check it out.
REALLY want to love the Orbi, but Netgear just seems to keep dropping the ball
When you talk of setting static DNS to 1.1.1.1 and 9.9.9.9 are you talking about the "Use these DNS addresses" instead of get automatically?
I understand the 1.1.1.1 is CloudFlare, but shouldn't the secondary DNS be 1.0.0.1?What is the 9.9.9.9?
Other than that you just increased the IP address table, but who needs more than 100 devices?
Not sure why this would have any effect?
I have created DHCP (static - LAN only of course) IP addresses for all my devices so that they always have the same IP address.
I also did this so that I could forward ports for Xbox Live, but have been reading that this isn't necessary any longer if UPNP is enabled?
Home is 6500sq ft. I recently enabled these Beamforming and MIMO and fast roaming options and they don't seem to make any difference, good or bad
