globespy
Jul 18, 2018Apprentice
Horrible Performance issues with Multi-users - no it's not my Internet connection
My 12 year old is here on vacation staying with me.
We decided to play Xbox last night, she was wifi connection (likely connected to the upstairs 2nd satellite), I'm hardwired to the main router un...
Jul 18, 2018Guru - Experienced User
You can review this and see if he helps you:
I set this up for my friend who has 3 xbox consoles, two are gamers, one is a streamer.
I have two xbox consoles on my system. Zero issues with gaming or XBL chat. We both game with the friend mentioned above and with others. Gaming and Chat works for us.
globespy
Thanks very much for the reply!
I will check it out.
REALLY want to love the Orbi, but Netgear just seems to keep dropping the ball
- globespyJul 18, 2018Apprentice
When you talk of setting static DNS to 1.1.1.1 and 9.9.9.9 are you talking about the "Use these DNS addresses" instead of get automatically?
I understand the 1.1.1.1 is CloudFlare, but shouldn't the secondary DNS be 1.0.0.1?What is the 9.9.9.9?
Other than that you just increased the IP address table, but who needs more than 100 devices?
Not sure why this would have any effect?
I have created DHCP (static - LAN only of course) IP addresses for all my devices so that they always have the same IP address.
I also did this so that I could forward ports for Xbox Live, but have been reading that this isn't necessary any longer if UPNP is enabled?
Home is 6500sq ft. I recently enabled these Beamforming and MIMO and fast roaming options and they don't seem to make any difference, good or bad
Why would you disable daisy-chain backhaul?
Both my satellites are in locations next to ethernet, so they have 1GB ethernet for backhaul istead of relying on the wifi band normally used for this.
Or is the daisy-chain backhaul something else that I do not understand that would mean disabling it would be benficial?
- FURRYe38Jul 18, 2018Guru - Experienced User
globespy wrote:
When you talk of setting static DNS to 1.1.1.1 and 9.9.9.9 are you talking about the "Use these DNS addresses" instead of get automatically? YES.
I understand the 1.1.1.1 is CloudFlare, but shouldn't the secondary DNS be 1.0.0.1? You can.What is the 9.9.9.9? Quad Nine is another DNS service recommended by an acquaintance of mine.
https://en.wikipedia.org/wiki/Quad9
Other than that you just increased the IP address table, but who needs more than 100 devices? No, the pool was decreased. Default NG pool is 192.168.1.2 thru .254. I use .100 thru .200. You can make it just about any size as long as it fits the needs and device count you have.
I have created DHCP (static - LAN only of course) IP addresses for all my devices so that they always have the same IP address. You mean Reservation IPs right? Reservation IPs are set ON the router. Static IPs are set on the devices.
I also did this so that I could forward ports for Xbox Live, but have been reading that this isn't necessary any longer if UPNP is enabled? Disable any PF rules for using XBL. uPnP is only needed for this. It's what I and others use for all xbox console configurations. XBL doesn't need any PF rules. Also set NAT Filter to OPEN if you have two or more consoles that game online. This helps get OPEN NAT on the dashboard and in same game played on both consoles. If you don't do much multiplayer gaming, then you can leave the NAT Filter at SECURE.
http://badmodems.com/Forum/viewtopic.php?f=6&t=21&sid=4fb09991e3e33dadc1595014a38bf269
If you have LAN connections at the remote locations where the satellites are where the wire there goes back to the router, it would be preferred to use the wired backhaul for the satelites instead of wireless.
My home is 5000sq ft, main router is at one end up stairs and the satellite is at the opposite end. 40 feet in between. Great coverage and performance, both wireless and wired. Mines wire connected which I prefer. So is my friends system.
Beamforming is good to have enabled. MIMO is if you have MIMO supporting devices. Daisy Chain is for two or more satellites piggy backing wirelessly of the other. Not needed for wired back haul. Fast Roaming is also kind of dependent upon client handling and design of roaming around the house and the ability to switch wireless sources whlie traversing area and signal coverage. Some device aren't designed well where others maybe more in this area. I only have Beamforming enabled for my system.
Thanks again Furry!
There's pro's and cons to the setting a device static IP, the main pro is that if your router's DHCP software is sketchy.
Whilst DHCP 'can' change the IP address, I've never seen it happen and the advantages of having all device IP's controlled centrally has always been more appealing to me. DHCP reservations are just 'safer' and avoid potential boob trap scenarios that can happen with devie specific static IP addresses when things go wrong.
But I do see why some people would do it, if it works then it works.
That being said, I'm not aware of any reasons why this would change a specific device from suddenly hogging too much bandwidth and interfering with others. That's a QOS issue.
I will disable the PF rules - thanks for that! May well have been the issue as both Xbox consoles use the same ports and you can't assign the same ports to be forwarded for 2 different consoles.
I need to find some way to monitor what's going on in realtime if this happens again.
Why Netgear have yet to implement a QOS and device/bandwidth management option on the Orbi is just bewildering.
We should start a petition, if anything people going through forums trying to decide on a new mesh type device (Orbi isn't really mesh) may stumble across this and go buy something else. Had I know, I likely wouldn't have had the Orbi on my shortlist.Only way to make a company do something is to impact their profits/public reputation and perception of quality or lawsuits.
Sad, but the only thing that makes them do anything quickly is money, as in losing it or the risk of losing it.
