XL25A's avatar
XL25A
Tutor
Jan 14, 2023
HORRIBLE wifi speed but ULTRAFAST via ethernet ports
Issue:
Cable modem (SPECTRUM) delivering 350+ Mbps INBOUND with near equal throughput (measured via FAST.COM) to devices via Ethernet ports on two satellites.
Wifi throughput, HOWEVER, typically begins with a long delay at 0Mbps before:
- starting in Kbps and meandering around that range to settle in Kbps
- starting in Kbps and bouncing chaotically up and down over the course of about a minute in the 2 to 8 Mbps range before settling back down to anywhere from Kbps to 8 Mbps range.
Sometimes rebooting improves responsiveness at the beginning of the test and yields anywhere from 50 to 150 Mbps. However, by the next day or so performance degrades back to utterly pathetic as outlined above.
ORBI HARDWARE - distributed in somewhat of hub arrangement
Daisy Chain OFF – Guest Network OFF
RBR50
2 RBS50
RBS40V (no Alexa)
RBS50 #1 and RBS40V are at least 30 feet from RBR50
RBS50 #2 is 24 feet from RBR50 – it can’t be any further away.
Wifi Backhual to RBR50 = GOOD ON ALL
16 connected devices allowed via ACCESS CONTROL and none of which are configured in a NETWORK LOOP
DEVICES CONNECTED DIRECTLY TO RBR50 via POE SWITCH OUTPUT
3 POE cameras
1 Ooma phone
DEVICES CONNECTED VIA ETHERNET PORTS ON SATELLITES at 350+ Mbps
RBS50 #1 - iMac
RBS50 #2 - iMac, MSI laptop, LG#1 TV
RBS40V - 1 non POE camera
DEVICES CONNECTED VIA WIFI
1 LG#2 and 2 VIZIO TV’s
iPhone #1
iPhone #2
iPad #1
iPad #2
RBR50 AND RBS50 2.7.4.24
RBS40V 2.6.2.8
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected to?
DOCSIS EU2251
1700
Channels set to 10 (it was the empty channel via Wifi Commander at the time) and 36 (empty as well)
Wifi Commander shows my network producing 4 named radio frequencies and 1 mac address frequency.
2.4Ghz signal strength varies from -24 to -50
5G varies from -38 to -62
There are approximately 8 local systems with signals anywhere from -60 to -85 (some stable on a channel and others roaming)
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Enabled
Disable ARMOR – NO IMPROVEMENT
Daisy Chain – set to OFF
Fast Roaming – deselected
IPv6 - disabled
20/40 Mhz – deselected (There is no 40Mhz only setting)
Setting PREAMBLE to SHORT or LONG did not improve things so I reset to Auto
  • CrimpOn's avatar
    CrimpOn
    Oh, darn. Appears that WiFi Commander requires a Microsoft Account to download.  I have been satisfied with WiFi Info View from Nirsoft (totally free) https://www.nirsoft.net/utils/wifi_information_view.html .  Is WiFi Commander worth the hassle?
    Just to clarify, with four active WiFi access points, you should see:
    • 4 Access points broadcasting the primary WiFi SSID on 2.4G (in your case channel 10)
    • 4 Access points broadcasting the primary WiFi SSID on 5G
    • If the guest WiFi is enabled, there should also be a total of 8 access points broadcasting the guest SSID.
    With those signal levels, the WiFi transmission should be fine, with 2.4G devices never reaching a link rate above 400Mbps and 5G devices reaching a maximum link rate of 866 bps.
    It wasn't entirely clear (to me) how the WiFi performance is being measured.
    • XL25A's avatar
      XL25A
      Tutor
      I understand the wifi signal *should* be fine. It very much is not.
      I use iPhone/iPad to connect to fast.com. I've attached an image of the wifi commander showing the 8 SSID and one mac address. My network is simbataji.
      • plemans's avatar
        One thing I like to try when I'm having issues with my mesh system is to shut off the satellites and just test the router's speeds.
        And test them for a bit to see if they stay stable. Its a bit of a pain in the rear but it helps to figure out if the router is causing the issues or something with the satellites.
        Is this issue new or has it been going on for a while?
