RobertWycoff
Jan 20, 2018Aspirant
How can I convert WiFi to Ethernet?
I have an ethernet cable in the room where one of my Orbi Satellites is. Can I just plug in the ethernet cable to use it or do I have to reboot the Orbi? What is the procedure?
- Jan 20, 2018
You just have to connect the satellite via ethernet to the Orbi router. It doesn't matter, if you do this directly between them or via a switch. Afterwards, you will have to restart the satellite and wait a couple of minutes. It takes some time, before the ethernet backhaul gets noted in the GUI. What you will also get, however, is the messed up states in the attached devices page, where all clients that are active on the sat are displayed as wired to the router. The sat's web UI will provide correct states.
RobertWycoff
I guess the ethernet ports on the Satellite are output and not input, so there is no way to connect them to my network with ethernet.
Am I correct?
budy
Jan 20, 2018Luminary
- RobertWycoffJan 20, 2018Aspirant
budy wrote:You just have to connect the satellite via ethernet to the Orbi router. It doesn't matter, if you do this directly between them or via a switch. Afterwards, you will have to restart the satellite and wait a couple of minutes. It takes some time, before the ethernet backhaul gets noted in the GUI. What you will also get, however, is the messed up states in the attached devices page, where all clients that are active on the sat are displayed as wired to the router. The sat's web UI will provide correct states.
Ah. Now I remember. Backhaul? Is that what this is? OK, thanks for the warning. My phiysical layout is gateway ethernet to Orbi, Orbi ethernet to 8-port gigabit switch, switch ethernet to Orbi Satellite. I will give it a try. I should be able to go back to wifi if I can't get it running.
Thanks.
- budyJan 20, 2018Luminary
This should just work fine. My setup is router <-> Orbi router (AP mode) <-> Zyxel Switch <-> Orbi satellite. I suspect some multicat traffic is being generated by the Orbi devices and as long as the switch doesn't block those, they will find each other just fine.
budy wrote:This should just work fine. My setup is router <-> Orbi router (AP mode) <-> Zyxel Switch <-> Orbi satellite. I suspect some multicat traffic is being generated by the Orbi devices and as long as the switch doesn't block those, they will find each other just fine.
Hmm. How do I know that it is working?
