CliffWang
Jan 23, 2018Aspirant
How can I sync my RBR50 with EX7500
I used to have my AC1900 + EX7500 configuration. However, it was not very stable. The communication between AC1900 and EX7500 drops very often. Recently I decided to upgrade my router to RBR50. T...
DarrenM
Jan 25, 2018Sr. NETGEAR Moderator
Yes they will work together but the ex7500 will not show up as a satellite for orbi.
DarrenM
CliffWang
Jan 25, 2018Aspirant
I have successfully connected both 2.4 and 5 GHz on the EX7500 to RBR50. Is that right configuration? Should I connect only 5 GHz only to make it as a fastlane? By the way, my laptop sometimes keeps the WiFi connection, but it losts the Internet connection for seconds. It's anything wrong for my configuration?
- DarrenMJan 25, 2018Sr. NETGEAR Moderator
If you are seeing speed issues you can try fastlane to improve that.
DarrenM
