CliffWang
Jan 24, 2018Aspirant
How can I sync my RBR50 with EX7500
I used to have my AC1900 + EX7500 configuration. However, it was not very stable. The communication between AC1900 and EX7500 drops very often. Recently I decided to upgrade my router to RBR50. T...
DarrenM
Jan 25, 2018Sr. NETGEAR Moderator
If you are seeing speed issues you can try fastlane to improve that.
DarrenM
CliffWang
Jan 25, 2018Aspirant
How to setup fastlane between Orbi RSR50 and EX7500? Thank you.
- DarrenMJan 26, 2018Sr. NETGEAR Moderator
I was wrong the ex7500 does not have fastlane as it is already using a dedicated band to connect to the router so its already fastlane in a sense.
DarrenM
- CliffWangJan 26, 2018Aspirant
Got it! Thank you for the information. I actually found out one interesting thing. If I remove EX7500 and use RBR50 only, the WiFi signal is much better and won't have Internet drop. However, two rooms around the corner won't be covered well. I will reallocate my RBR50 and use EX7300 as an AP, since I still have EX7300. Any suggestion if I should use same SSID for EX7300?
