CliffWang
Jan 23, 2018Aspirant
How can I sync my RBR50 with EX7500
I used to have my AC1900 + EX7500 configuration. However, it was not very stable. The communication between AC1900 and EX7500 drops very often. Recently I decided to upgrade my router to RBR50. T...
CliffWang
Jan 25, 2018Aspirant
How to setup fastlane between Orbi RSR50 and EX7500? Thank you.
DarrenM
Jan 26, 2018Sr. NETGEAR Moderator
I was wrong the ex7500 does not have fastlane as it is already using a dedicated band to connect to the router so its already fastlane in a sense.
DarrenM
- CliffWangJan 26, 2018Aspirant
Got it! Thank you for the information. I actually found out one interesting thing. If I remove EX7500 and use RBR50 only, the WiFi signal is much better and won't have Internet drop. However, two rooms around the corner won't be covered well. I will reallocate my RBR50 and use EX7300 as an AP, since I still have EX7300. Any suggestion if I should use same SSID for EX7300?
