BeeCH
Oct 18, 2021Aspirant
How do I add a TP-link extender to ORBI RBR20
I’m having trouble with my Ring door bell connecting to my ORBI like a lot of people during Live view. Someone had success with incorporating their TP-link extender to their Orbi. Just wondering if an...
Oct 18, 2021Guru - Experienced User
it won't mesh with the systems because they're not compatible.
But you might be able to install the tp-link device manually. you'd be best to check with the tp-link forum/support on how to manually install the tp-link device instead of using wps.
