MelB
Mar 10, 2017Aspirant
How do I determine the IP address of my RBR50 and RBS50 under macOS?
 My computer is a Macbook pro runnilung Sierra.  I want to be go to the IP Address to see my settings.
- Mar 10, 2017
1. Navigate to orbilogin.com in a broswer. Log into orbi. Check settings in GUI. Satellite IP address is shown under attached devices.
OR
2. Try navigating to http://192.168.1.1 or http://10.0.0.1 in a broswer. Log into orbi. Check settings in GUI. Satellite IP address is shown under attached devices.
OR
3. Option-click on WiFi icon on Mac menu bar at top of screen. Look for "Router: A.B.C.D" where A.B.C.D is the IP address . Log into orbi at that address using browser. Check settings in GUI. Satellite IP address is shown under attached devices.
OR
4. If Orbi is behind another router, log into the other router, and look for Orbi IP address in the list of attached devices.
OR
5. Use the Netgear Genie App.
st_shaw
Mar 10, 2017Master
OR
OR
OR
OR
