savaasio
Jul 04, 2023Aspirant
How do I enable bridge mode after setting up an Orbi RBR50v2
I have setup my Orbi with an old Verizon DSL router/modem
After I setup the Orbi, I was no longer able to access the administrator page of my old router/modem, and I had forgot to enable bridge mode and disable wifi on the old router/modem. To enable bridge mode and disable wifi, i need to access the old administrator page. Are there any ways to access the administrator page of the router that the orbi is connected to?
Many users would temporarily unplug the Orbi from the old router and connect a wired computer (desktop, laptop) to the old router. However you were able to log in before should work when connected directly.
- Disconnect Orbi from modem/router.
- Reset modem/router.
- Go into modem/router controls
- Put it into modem/only mode
- Set up Internet connection
Then go through the usual network set up process
Be sure to restart your network in this sequence:- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
My experience with modems is that it isn't easy to get at their controls when they are in front of a router. Fortunately it is something that you do rarely, if ever.
