hk510
Dec 25, 2018Aspirant
HOW DO I GET PHONE SUPPORT?
How do I get phone support for my new RBR50.
Setup is not working.
I have registered the product.
The web site is not giving me any option other than to post here.
HOW DO I GE...
Dec 25, 2018Guru - Experienced User
What problems are you having with the system?
Maybe we can help you out here if you can help with some details...
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What WPA security modes are you using?
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Disney Circle: https://community.netgear.com/t5/Orbi/WARNING-Firmware-2-2-1-210-is-junk/m-p/1667485/highlight/true#M45926
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
HOW DO I GET A HUMAN ON THE PHONE BEFORE I JUST RETURN THIS PRODUCT?
