mossywell
Jun 23, 2018Star
How do I get support for Orbi Circle Premium?
The Circle web site says I need to go to Netgear for support:
https://support.meetcircle.com/hc/en-us/articles/115003197671-I-Need-Support-for-Circle-on-NETGEAR
"The team over at NETGEAR is best ...
mossywell
Jun 24, 2018Star
Hello, sorry that's just too cryptic for me. Are you saying that Netgear don't support it? If so, shouldn't the Circle people themselves be notified as they seem to think Netgear do? It would be appreciated if you just spelt it out for me please?
One observation: the link says that Circle prrmium on Orbi supports 3 features: Usage, Time limits and History that it doesn't.
DarrenM
Jun 25, 2018Sr. NETGEAR Moderator
Hello mossywell
What firmware version is your orbi system running?
DarrenM
- mossywellJun 27, 2018Star
Hi DarrenM, thanks for the reply.
I'm running V2.1.4.16
Cheers.
- DarrenMJun 27, 2018Sr. NETGEAR Moderator
What is the reason you can not enter a serial number?
DarrenM
- mossywellJun 28, 2018Star
The instructions on how to get support is the reason:
"The team over at NETGEAR is best equipped to help with any and all Circle on NETGEAR questions or issues. You can visit their support website for Circle here. Need more help? Contact their support team here. Make sure to tell them where you're from, check "I have a NETGEAR product without a serial number", and select Circle from the drop down menu. If you're asked for a purchase date, just put the date for your subscription renewal or when you enabled Circle on NETGEAR."
Are these instructions incorrect?
