konagal
Jan 31, 2018Aspirant
How do I set up the Orbi RBS50Y after I set up my Orbi RBK53 and one satellite?
I purchased both systems so as to have extended coverage including the RBS50Y for outside coverage. How do I set up the RBS50Y after setting up the RBK53 router and one satellite from that model? Wou...
konagal
I forgot to mention I want to do it in the "Daisy Chain" setup method with the RBS50Y the first satellite in the chain and the satellite from the RBK53 as the next one. Is there a certain thing I have to do for that? Will it ask me if I want to set it up that way or do I have to specify it in a certain way? So, you're saying just click on the sync button after I set up the router in this method?
DarrenM
Feb 01, 2018Sr. NETGEAR Moderator
Yes just follow the normal setup method and within the settings you enable the daisy chain option.
DarrenM
- konagalFeb 02, 2018Aspirant
I called Netgear and had a technician help me set them up over the phone. He said there is NO "enabling" the Daisy Chain method. I also read that I must select that method on setup but I did not see anything to select. Can you help me find that method so I can make sure I am in Daisy Chain mode?
I FOUND it and the Daisy Chain method IS checked. I found in in Advanced>Advanced Set Up>Wireless Settings. Thanks
