PuRePoison
Sep 07, 2019Aspirant
how do i setup Wake on LAN AND WAN WoL
SO! I'm Struggeling hardcore to Wake on Wan. i have WoL setup no probs bob but i can only access from inside my network. Can anyone help me configure so i can access from outside my network? im tryin...
ekhalil
Sep 08, 2019Master
PuRePoison wrote:.............. i can only access from inside my network. .......
If you can access it from inside the network, then your best option is to use VPN to connect to your network when you're outside and then follow the same procedure you follow when you're inside the network.
- PuRePoisonSep 08, 2019AspirantHmmm, honestly its been a while since ive been at the pc.. i used to be pretty good with this stuff but its all lost on me now. I know what VPN stands for, i forgot what it does and how to use it. There fore without indepth explanation i dont understand how this will help. Thanks for your response and time!
- ekhalilSep 08, 2019Master
PuRePoison wrote:
........ I know what VPN stands for, i forgot what it does and how to use it. ....VPN is a secure tunnel over internet between a device and Orbi. But establishing such a tunnel you will get a provate IP address from Orbi and you will be able to have access to your home network as if you're connected to home wifi or LAN.
Here is information about how to setup VPN in Orbi, the following link is for iPhones, but there are similar ways to setup Windows computer, and MacOS computers:
https://kb.netgear.com/31489/How-do-I-use-VPN-on-my-Orbi-system-with-my-iOS-device
