kmav1
Feb 18, 2017Aspirant
How do I turnoff my old WiFi network?
I have successfully setup my new Orbi RBR50 router with two Orbi RBS satellites at my home but my old WiFi network still shows up. I have a Verizon DSL modem made by Actiontec, Model:GT784WNV which w...
- Feb 19, 2017
Thank you. It worked! So now that I turned off the wifi radio on my Actiontec modem/router, what do I gain by having just one wifi(Orbi) network throughout my home? Is there any increase in the wifi strength or the overall speed of my internet? Or is the benefit more in terms of prevention of accidental switching into the 'old' network?
cue003
Feb 19, 2017Apprentice
You could gain a couple of things:
1) more orbi strength possibly because of less potential interference from the other network (depending on wifi channels etc that were being used)
2) you gain possible prevention of accidental switching to the old network as you stated
3) you gain simplicity in having one network vs multiple
4) you gain faster IN HOME communication between devices for file transfers or computers or on premise video surveillance or other in home functions
5) you get Wifi blanket coverage (hopefully) throughout your home and in areas where you had little to no signal before you now have fully strength or much better coverage.
As far as your internet speed that is a function of your service provider. Your devices could actually be faster than what they were before Orbi but you are still limited when it comes to communication to the INTERNET based on the bandwidth you pay for.
