crement
Nov 27, 2017Follower
how does Orbi AC3000 RBK50 work with Motorola SBG6580 (2 in 1 model/router)?
Hi There,
I plan to buy Orbi AC3000 (RBK50). I have Motorola SBG6850 now, which is a modem/router 2 in 1.
1st question. Do I still need the Motorola SBG6850?
If so, how should I set up both of them to have the best Wifi speed?
Thanks in advance!
Best,
Eddie
1 Reply
- DarrenMSr. NETGEAR Moderator
You still need the modem but you will need to bridge the modem so the wifi is not enabled on it.
DarrenM
