BretD
Nov 30, 2017Administrator
How does Orbi stack up against the rest? Orbi Vs. BT Whole Home WiFi & Google WiFi
The popular review site KITGURU pit Orbi vs. several other WiFi mesh and WiFi extender products, and found that Orbi WiFi System outperformed the rest in almost all tests. As expected the Orbi RBK50 AC3000 came out on top, but the RBK40 and RBK30 were not far behind, consistently getting great results too. At the extreme range of 32m, behind obstructions, the Orbi RBK50 was still able to provide a useable WiFi signal.
Visit KITGURU for the full WiFi speed results, with dozens of graphs, charts, and raw results. We posted just a few examples below of the charts and graphs in the full KITGURU review.
How is your WiFi Speed? Let us know in the comments below.
- RogerSCVirtuoso
Don't know if it's been mentioned here, but the smallnetbuilder (SNB) web site also provides test results. The tests there are on a wider variety of mesh products, including the eero and Deco, etc. So they're of interest as well. Of course, the Orbi does quite well in the SNB tests, too :-).
- BretDAdministrator
Would be happy if you would want to do a little write-up of the SNB Review / Shootout article. Then we can feature it!
- KyneApprentice
It's pretty awesome.
I wish - and know that other than Ubiquty's Amplifi HD, the competitors are in the same boat - the user stream fro Orbi was utilizing 3x3 streams (vs just 2x2). Seems to make MU-MIMO a bit of a dud, and also usesl less streams than Apple devices (which utilize 3x3 radios)...
- worldofshayanApprentice
Does this mean tghat the Amplifi HD is better than the orbi or worse?
- RogerSCVirtuoso
worldofshayan wrote:Does this mean tghat the Amplifi HD is better than the orbi or worse?
I'd suggest that you go and look at the mesh system reviews/tests on smallnetbuilder.com. The main reviewer there does actual head-to-head tests of mesh systems (including the Orbi, which has only taken on a mesh aspect recently, it has been mostly a star topology until the implement daisy chaining between satellites, and Amplifi). A big reward for a little reading *smile*.
