Sdiver2489
Jan 26, 2018Apprentice
How does satellite ethernet connections work with and with ethernet backhaul
I set up my orbi and had a general question about the ethernet ports on the satellite. I assume these act to take internet access from the wireless connection and clients connect through there. My do...
linkwrt
Jan 26, 2018Guide
wrote:I set up my orbi and had a general question about the ethernet ports on the satellite. I assume these act to take internet access from the wireless connection and clients connect through there. My downside is twofold. First, The main router only has 4 ethernet compared to my previous 5 so I need to get a small switch to expand this a bit. Second, the satellite orbi ended up right next to my office computer which has wired ethernet access. I was thinking about connecting the ethernet to do ethernet backhaul and was wondering if this would then cause the satellite orbi to act as a wired switch so that my devices in my office aren't forced to go over the wireless connection. This would allow me to replace the switch I currently have there and use it to expand the ports on the router.
As a side question...I noticed my PC which connects to the router through a switch now takes quite a long time to discover the network to the point where it has internet. Is this just because I haven't set up a static IP like I used to have or is there something else I should look into?
It's simple.
Power off RBS50, connect lan cable from the RBR50 to RBS50 port 1 then power on RBS50. Satellite will be configured default as access point. Other lan ports can be used like a switch.
