tgiv
May 03, 2018Aspirant
HOW FAR APART can router satellite be?
So I am reading a "solved" question that never gets a straight answer, not even one "if everything were perfect" one, just generizations & what ifs and don't-blame-me-later due to a wrong answer ... ...
May 03, 2018Guru - Experienced User
Beginning distance between router and satellite should start at 30-40 feet. A wif router alone can handle up to 30-40 feet range. Line of site is always best however, 2-3 Wooden and sheet rock walls can still not impact signals. Concrete and metal embedded walls will impact signal.
I have a 5000sq ft home and have my 1 satellite at the opposite end of the house 40 feet in between. Coverage, range and performance is great. 3 wooden walls in between.
Size of home is important as well small size, a router alone can handle most of this coverage. Mid to large size, then you need to place a satellite in low signal or dead areas.
