jimbobbob
Apr 17, 2018Tutor
How many Orbi's can I return? I bet a whole bunch.
Trying to add an RBS50 to a RBK50 system. Instructions say turn it on, wait until light is solid white. Today's device arrived, took 10 minutes to stop flashing, then turned red. Before I even mov...
Retired_Member
Apr 18, 2018
jimbobbob wrote:Trying to add an RBS50 to a RBK50 system. Instructions say turn it on, wait until light is solid white. Today's device arrived, took 10 minutes to stop flashing, then turned red. Before I even moved to step 1 or trying to start a sync. Reset the device, same behavior. Pissed me off. Back in the box it went. I suspect the instructions are wrong. But if they are, I'm going to return quite a few before I look for further advice.
Anybody know off hand if these instructions are wrong?
Red...? As in maybe too far from router..?? I'd move it closer to the router (if possible) and try again.
- jimbobbobApr 18, 2018Tutor
I already have a functioning RBK50 setup - router and satellite. I'm impressed with that system, although I recall the satellite on that system did not go according to instructions either (although I might be remembering incorrectly). That system's working great. New satellite is going in only 20 feet from the prior one (I want access to the Ethernet ports in this location).
But why did this satellite boot straight up into disconnected mode, when included instructions say it will come up with solid white light?
- FURRYe38Apr 18, 2018Guru - Experienced User
May have been in a bad configuration out of the box.
Does the Satellite work now?
I have the first satellite working, waiting for a replacement of the 2nd one to arrive. I'm waiting with baited breath to see if replacement boots the same way, I have my doubts about whether these legitimately still boot up the way the instructions say. I held the reset in for about 5 seconds until LED flashed, then power cycled, but Ring Light still came up same way. Unfortunately, sparse instructions don't say anything about reset procedure, and I'm pretty unhappy that I might have to go dig through a troubleshooting procedure. The conceptual promise is something like a 2 minute setup here for additional satellites.
