jimbobbob
Apr 17, 2018Tutor
How many Orbi's can I return? I bet a whole bunch.
Trying to add an RBS50 to a RBK50 system. Instructions say turn it on, wait until light is solid white. Today's device arrived, took 10 minutes to stop flashing, then turned red. Before I even mov...
jimbobbob
Apr 18, 2018Tutor
I already have a functioning RBK50 setup - router and satellite. I'm impressed with that system, although I recall the satellite on that system did not go according to instructions either (although I might be remembering incorrectly). That system's working great. New satellite is going in only 20 feet from the prior one (I want access to the Ethernet ports in this location).
But why did this satellite boot straight up into disconnected mode, when included instructions say it will come up with solid white light?
Apr 18, 2018Guru - Experienced User
May have been in a bad configuration out of the box.
Does the Satellite work now?
- jimbobbobApr 18, 2018Tutor
I have the first satellite working, waiting for a replacement of the 2nd one to arrive. I'm waiting with baited breath to see if replacement boots the same way, I have my doubts about whether these legitimately still boot up the way the instructions say. I held the reset in for about 5 seconds until LED flashed, then power cycled, but Ring Light still came up same way. Unfortunately, sparse instructions don't say anything about reset procedure, and I'm pretty unhappy that I might have to go dig through a troubleshooting procedure. The conceptual promise is something like a 2 minute setup here for additional satellites.
- st_shawApr 18, 2018Master
A new, unpaired, add-on satellite will come up flashing white while booting, then glow solid white. At that point you can pair it using the pairng process. An add-on satellite does not automatically pair, like the satellite that comes in a kit with a router.
If you happened to pres the Sync button on the back of the satellite, but did not press the sync button on the back of the router, then the satellite would try to pair and turn magenta when it fails. The satellite would also turn magenta if the pairing process fails, due to poor signal.
A reset requires inserting a paperclip into the reset hole, and holding it in until the LED flashes. You might try another reset and hold the reset in more like 30 seconds.
You might also try moving the satellite to within a few feet of ther router during the pairing process (assuming you get that far.) I have had to do this with mine to get it to pair.
