thatoneandonly
Apr 27, 2018Tutor
How Many Simultaneous Connections Can The Orbi WiFi Possibly Support (For Running A Webserver)
Hello,
I have been running a local webserver off of my Netgear Orbi system (via portforwarding). What's happening is that it will run fine for a while, then it will start to fail. The software ...
- Apr 28, 2018
Also be aware that this units are home class systems, not business class systems so having a web server may not be best on the Orbi system. if you need a ton of connections, you should look into a different router that can handle your appropriate web services for you needs. You can always connect the Orbi system in AP mode and use it as your wireless mesh system.
Apr 28, 2018Guru - Experienced User
