alokeprasad
Dec 13, 2020Mentor
How t ofind out the total bandwidth of my wireless backhaul?
Using Ver 2.5.2.4 How do I find out the total bandwidth suppotrd by the connecetion benween the RBR and RBS? The status is shown in the router (web interface) as "good". If I find the capaci...
- Dec 13, 2020
alokeprasad wrote:How do I find out the total bandwidth suppotrd by the connecetion benween the RBR and RBS? The status is shown in the router (web interface) as "good".
Bonus question: I have only one RBS1. But if I had more, RBS2, RBS3, in a daisychain to my 1st RBS, then would the bandwidth of all devices connected to all of my RBS1, RBS2, RBS3 be subject tto the bottleneck of the connection capacity between RBR and RBS1?
Yes, of course that "last link" will be the bottleneck. A "star" arrangement clearly offers the most througput, but may not be practical given the layout of the building.
Orbi reports the "transmission rate" of the backhaul link in response to a telnet command.
- On the Orbi "debug" page, Enable telnet on the router.
Browse to http://orbilogin.net/debug.htm
Login with the web site admin credentials ("admin" and password)
Check the box "Enable telnet" toward the bottom of the screen - Open a telnet client and connect to the Orbi router by IP address (often 192.168.1.1)
Windows has a built in telnet client that can be enabled from the "Programs and Features" control panel.
(It is under "Activate Features" on the left menu.)
There are many telnet applications for Windows, Apple, Linux, etc. (Even tablets). I personally use PuTTY because it allows me to have all my different telnet hosts defined in advance and can save a log of the session automatically. - Log in with the admin credentials
- Type this command: satelliteinfo wifi
I have two satellites (star). This is what the command shows for my Orbi:
root@RBR50:/# satelliteinfo wifi
"mac address" : "A0:04:60:xx:xx:xx",
"hop" : "1",
"bridge mac" : "A0:04:xx:xx:xx:xx",
"backhaul conntype" : "5GHz",
"backhaul rssi" : "-68",
"backhaul macaddress" : "A0:04:60:xx:xx:xx",
"backhaul phytxrate" : "780",
"backhaul phyrxrate" : "780",
"backhaul parentmac" : "A0:04:60:xx:xx:xx"
"mac address" : "14:59:C0:xx:xx:xx",
"hop" : "1",
"bridge mac" : "14:59:C0:xx:xx:xx",
"backhaul rssi" : "-59",
"backhaul macaddress" : "",
"backhaul phytxrate" : "866",
"backhaul phyrxrate" : "650",
}This reports the "transmit" and "receive" rates (at this moment) between each satellite and the router. I have no idea why they are different. As my internet speed is 200mbs, the Orbi is clearly capable of streaming more than I can get from the internet.
Whether this information is useful is a matter of conjecture. WiFi has a lot of overhead and is a "one talk at a time" medium. If all the traffic is in one direction, it might be possible to move a lot across the backhaul. If a lot of data is going "up the pipe", then the amount of data that can come "down" is reduced.
Hope this is helpful.
alokeprasad
Dec 17, 2020Mentor
Check the box "Enable telnet" toward the bottom of the screen- Open a telnet client and connect to the Orbi router by IP address (often 192.168.1.1)
There are many telnet applications for Windows, Apple, Linux, etc. (Even tablets). I personally use PuTTY because it allows me to have all my different telnet hosts defined in advance and can save a log of the session automatically.- Log in with the admin credentials
"hop" : "1",
"hop" : "1",
Is this the same as the web interface's Advanced Home -> Internet Port -> Show Statistics info?
That has a row for "WLAN Backhaul" with status as "1733 M", presumably Mb/s
Aloke
CrimpOn
Dec 17, 2020Guru - Experienced User
alokeprasad wrote:
pe this is helpful.Is this the same as the web interface's Advanced Home -> Internet Port -> Show Statistics info?
Yes, my "Show Statistics" does report 1733 which is definitely different than the satelliteinfo. My feeling is that the 1733 is reporting the "maximum possible", just as the 1000/ful is reporting the maximum possible connection rate (gigabit). The actual rate (in my case is less).
