DEJohns's avatar
DEJohns
How to add second Orbi satellite (RBS50) in a Daisy chain topology
I recently installed an Orbi router as an Access Point (AP) within an existing FiOS network. I also changed the SSID in the Orbi to my existing one. Along with the Orbi router I also installed a sing...
  • brenth's avatar
    Jan 14, 2018
    Sync the second RBS50 with the RBR50.  Then, with daisy-chain enabled in the RBR50, the second RBS50 should automatically connect to the first RBS50 if it's closer than the RBR50.
