thatoneandonly
Aug 07, 2018Tutor
How To Be Autmatically Notified When Netgear Releases a Firmware Update
Hello,
So I am wondering, is there currently a way to be autmatically informed when Netgear releases a new firmware update for the Orbi Router? Is there a way to sign an email adress up to be a...
Aug 07, 2018Guru - Experienced User
NG doesn't provide any notifications of FW updates. They do occasionally send out notifications and reminders of security issues and to keep checking your system and support sites for FW updates if you have registered your product with NG. You just have to keep checking here in the forums, NG support site download page for the model you have or check the onboard FW update section of the router.
