CESAR--'s avatar
CESAR--
Follower
Jun 26, 2019
HOW TO BROADCAST THE SSID ON THE ROUTER
HOW TO BROADCAST THE SSID ON THE ROUTER, since the router is already online and working but i can't see it in my WIFI login page
  • CrimpOn's avatar
    CrimpOn
    This issue has come up a couple of times recently, mostly in connection with Windows 10.
    On the Orbi web interface, Advanced Tab, Advanced Settings, Wireless Settings, there is a check box for "Broadcast SSID".  If it is checked, then the Orbi is broadcasting SSID.  There are separate check boxes for 2.4G and 5G.
    If the boxes are checked, then there may be another issue.
  • FURRYe38's avatar
    Please use a wired PC to connect to the back of the RBR and a web browser and navigate to orbilogin.net.
