apgomez3's avatar
apgomez3
How to change DNS settings on RBR50
I’m looking to change my DNS resolver from my ISP to Cloudlfare’s 1.1.1.1. I can’t seem to find where to do this.
    • michaelkenward's avatar
      michaelkenward
      For future reference, the manual has a section on this.
      Visit the support pages:
      Support | NETGEAR
      Feed in your model number and check the documentation for your hardware.
    • apgomez3's avatar
      apgomez3
      The radial button next to Use These DNS Servers is grayed out and I can't edit.
      • FURRYe38's avatar
        Be sure you don't have Armor or Circle enabled.
  • FURRYe38's avatar
