RebelDad's avatar
Jun 26, 2019
How to change the transmit power on Orbi RBR50?
Is there a way to change the transmit power on Orbi RBR50 other than using telnet?
This should certainly be available in the web interface but I can't find it.
Thanks.
  • Advanced Tab->Advanced Settings->Advanced Wireless Settings
  • CrimpOn's avatar
    CrimpOn
    • CrimpOn's avatar
      CrimpOn
      The lowest level supported on the web interface is 25%.  If a lower level is desired, only the telnet approach works for that.
    • RebelDad's avatar
      RebelDad
      Star
      Thank you. I was on that page and completely missed it.
