Bovie
Dec 26, 2021Follower
How to connect an external hard drive to my Orbi AC 3000 system
The Orbi has an usb port but it doesn't have usb hard drive support for them.
You can buy a cheap device like a raspberry pi and setup a nas with it. Or a cheap nas enclosure that supports ethernet connection.
Easier said than done.
NAS and "cheaper" don't usually go together. At least, not if you are looking for something in the same price bracket as USB enclosures.
You can make a raspberry pi work as a nas device :)
