MarcoBru's avatar
Nov 16, 2020
how to connect Orbi 50 to FTTC
Hello
I'm moving my connection from a terminal adapter PPOE to a FTTC fiber.
SO I need a external modem.
How can I setup everything in order to keep the Orbi as DHCP server?
thanx
  • CrimpOn's avatar
    CrimpOn
    MarcoBru wrote:
    Hello
    thanx
    Every fiber provider that I have heard of includes a fiber converter box (an "ONT") as part of the installation.
    This has a gigabit ethernet jack on it, so you will connect the Orbi directly to the ONT with an ethernet cable and the Orbi will continue to function as a router and provide IP addresses to your devices.  You do not need to purchase a modem.
    • MarcoBru's avatar
      MarcoBru
      Tutor
      thanx but actually not
      This FTTC will be connectd with a RJ11 (phone plug) so I need a modem
      • CrimpOn's avatar
        CrimpOn
        Oh, my.  There I go assuming again.  Sorry.
        Would you mind sharing which company is providing this FTTC?
  • FURRYe38's avatar
    First contact your ISP to see what is required by them regarding any modems, etc.
    For modems with a built in router, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
