Jonsax21
Nov 14, 2017Aspirant
How to connect to Comcast internet
Can’t get my xfinity modem to allow orbi to access network. Have followed all instructions. Can anyone help? Thanks, Jon.
Jonsax21
Nov 21, 2017Aspirant
st_shaw, Thanks for your reply. I don't know how to set the Orbi to "access Point Mode." I can find no such option in the app or in the instructions that came with it . . . Can you advise? Thanks.
st_shaw
Nov 21, 2017Master
Using a web browser, log into the Orbi's web admin GUI, located at the IP address of the Orbi.
Navigate the menu system to: Advanced -> Advanced Setup -> Router /AP Mode.
Select AP mode.
Make sure you wire the Orbi to your Comcast modem as shown in the AP Mode GUI diagram. You must connect the yellow Internet port to a LAN port on your Comcast modem.
- Jonsax21Nov 21, 2017Aspirant
Sorry, how do I find the IP address? The address I find from the wifi signal that appears on my phone looks to be a generic IP address and when I try to go to it, I get a "This site can't be reached" screen . . .
- st_shawNov 21, 2017Master
Tried that. Tells me I'm not connected to Orbi's wfif network . . . I thought I was making progress. Tried a new thing: in my laptop's (MacBook pro 13") network preferences, I selected the Orbi network name. Below, I selected "Connect" next to 802.1X WiFi". This then took me through an entire set-up of the orbis wiFi station and extender. When I was done and had changed the password and saved all that, I was certain I had found the way to connect. But when I tried to connect, there was still no WiFi access to the internet. I tried restarting the Orbi. No change. Why is this so difficult? This is very frustrating!
