Jonsax21
Nov 14, 2017Aspirant
How to connect to Comcast internet
Can’t get my xfinity modem to allow orbi to access network. Have followed all instructions. Can anyone help? Thanks, Jon.
Jul 25, 2018Guru - Experienced User
What is the Model# of the Arris ISP modem/router combo? Not the RBK.
jp4120
Jul 26, 2018Guide
arris model is 802.11ac
- FURRYe38Jul 26, 2018Guru - Experienced User
That is the wireless mode it supports. There should be a sticker under or in back of the modem that give a Model#:
- jp4120Jul 26, 2018Guide
Arris TG1682G
Ok, wanted to confirm. Yes you have a modem/router combo.
I wanna say my friend has this same modem and I was able to bridge it.
You can review this:
https://www.youtube.com/watch?v=crWzQbo-BFI
https://www.youtube.com/watch?v=Rhxl1_tiBQM
https://arris.secure.force.com/consumers/articles/General_FAQs/TG862G-NA-Bridge-Mode-Setup
You might check to see if there is a actual Gateway / Bridge mode feature under WAN settings or anywhere with in the modem...
At any rate, you'll need to review the 3 suggestions regarding modem/router combo units and see what works best for you.
