ChihSiang
Feb 08, 2018Aspirant
How To Disable 5g Permanently On Orbi Router
Hi all, I have a need to disable the 5hz band permanently on my Orbi system but I can't seem to find any way to do it via the app or via Oribilogin.com. Can anyone help to advise if there's a way to ...
tsig
Feb 09, 2018Luminary
you could just set up the guest 2.4 and use that, unless somehow the 5 ghz is affecting something else. I think you can turn the power down though?
