ChihSiang
Feb 08, 2018Aspirant
How To Disable 5g Permanently On Orbi Router
Hi all, I have a need to disable the 5hz band permanently on my Orbi system but I can't seem to find any way to do it via the app or via Oribilogin.com. Can anyone help to advise if there's a way to ...
Apr 03, 2018Guru - Experienced User
Tring to disable 5Ghz would be counter productive and would not help since this is a MESH system which depends on both radios running. Kind of defeats the design and purpose of a wireless MESH system.
avtella
May 23, 2018Prodigy
Orbi isn't exactly a "Mesh" product because it uses a dedicated backhaul (5ghz in this case via a 2nd 5Ghz radio). This makes it better performing than its Mesh counter parts like the Google Wifi etc as you dont lose bandwidth from the first to last satellite as its in a star topology. They did add the chain feature now though. Anyhow due to the way Orbi works, you can't disable the 5Ghz radio via GUI. Probably can via telnet though, but you would lose connectivity with the satellite unit. For your purpose you were probably better off with an extender instead of the Orbi.
