Anonymous
Nov 17, 2019How to disable 5GHz side of Orbi network
I just bought a Wemo Mini WiFi plug and Smart Dimmer switch that only use 2.4Ghz.
Is there an easy way to temporarily disable the 5Ghz network so I can associate the WIFi plug with Apple HomeKit? The problem is that my iPhone connects to the 5Ghz network and cannot connect with the plug which is connected to the 2.4Ghz side.
I saw a post that has instructions for using a command line control but before venturing into this I’d like to know if there’s a simpler way to disable the 5Ghz side.
Thanks.
Under Advanced Tab/Advanced Settings/Wireless Settings. You can uncheck the broadcast SSID check box for each frequency.
It doesn't shut off wifi but it disabled the ssid broadcast. Sometimes this is enough to allow your device to connect. After you disable it, turn off and then back your your phone wifi. Or you can try turning down the 5ghz broadcast strength.
