gman88's avatar
gman88
Tutor
Apr 03, 2021
How to disable AP Isolation RBR730 ?
I would like to disable AP Isolation.  As per the image below, AP Isolation is set to "on" for both Guest and Main networks (see attached image).  I would like to disable it for either or both networks.
I see no way to disable for either network using the web interface http://www.orbilogin.com/, nor do I see a way to disable via the Orbi App.  There is no checkbox under "Wireless Settings" nor "Guest Network", which is where I would expect to see one.
Any guidance here?
RBR753
Firmware Version
V3.2.16.22_1.4.9
