WiredWorker's avatar
WiredWorker
Initiate
Aug 02, 2018
How to disable wireless isolation ORBI
Hi,
I have a RBR50 with two satelites.  A few weeks ago I bought a Homepod from apple but I can`t control my room by using siri. Everything is set up, and it works from my iphone but nut with my homepod. I asked Apple support what the problem could be. Their answer was that it could be the wireless isolation because this prevents direct communications with other devices on the same wired/wireless network. I think this make sense! So how can I disable it on my ORBI?
-WW
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    There is no wireless isolation on the main network but there is on the guest network.
    DarrenM
    • WiredWorker's avatar
      WiredWorker
      Initiate
      But why does my Homepod not work with Siri? Are other Orbi users having the same problem? I think this is a network problem.
