SashX
Mar 14, 2025Aspirant
How to Flash an RBR50 to an RBS50, and how to flash back an RBS50 back to an RBR50?
As the title says, how can I flash easily in either direction (RBR50 -> RBS50 and back if necessary). Thanks!
Mar 14, 2025Guru - Experienced User
Flash FW?
Always update FW on the RBS first, then RBR lastly. You can connect any PC to the RBR or to the RBS and update FW using the RBS web page as well as the RBR web page.
SashX
Forgive me for sounding like a noob but how would I do all this? Is there a step by step instruction somewhere?
I have just been using the Orbi app on my phone to add satellites and that's about it.
From what I see in the Orbi app the firmware of all my devices is the latest I believe.
- FURRYe38Mar 14, 2025Guru - Experienced User
https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-com
https://kb.netgear.com/000037217/How-do-I-check-and-manually-upgrade-the-firmware-on-my-Orbi-satellite 🛰️There is a good PDF file attached here with more details if you want to review it:
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2359585/highlight/true#M53030
