SashX
Mar 14, 2025Aspirant
How to Flash an RBR50 to an RBS50, and how to flash back an RBS50 back to an RBR50?
As the title says, how can I flash easily in either direction (RBR50 -> RBS50 and back if necessary). Thanks!
SashX
Forgive me for sounding like a noob but how would I do all this? Is there a step by step instruction somewhere?
I have just been using the Orbi app on my phone to add satellites and that's about it.
From what I see in the Orbi app the firmware of all my devices is the latest I believe.
Mar 14, 2025Guru - Experienced User
https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-com
https://kb.netgear.com/000037217/How-do-I-check-and-manually-upgrade-the-firmware-on-my-Orbi-satellite 🛰️
There is a good PDF file attached here with more details if you want to review it:
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2359585/highlight/true#M53030
