AniDutta's avatar
AniDutta
Apprentice
Oct 08, 2016
How to force a device to be connected to router and not satellite?
The main Orbi router is in my office and my media room is next to it on the second floor. I have a Chromecast that always connects to the satellite on the first floor. This results in buffering if I cast something from a device that is wirelessly connected to the main router. Any thoughts?
  • this would suggest the signal from the sat is better than the router and the system is doing the right thing , you cant really tell the client which it should connect to
    • GaryInEdmond's avatar
      GaryInEdmond
      Guide
      The problem with this is, if the satellite signal is only slightly better than the main router, it will connect to the satellite.  Unless you are gaming, this is probaly not a big deal.  If you are gaming, and your ping doubles because you are connected to the satellite instead of the main router, your gaming performance actually drops.  The amplifi HD does this be connecting automatically to the main router unless the signal drops below a certain threshold.  It will then connect to the satellite.  I hope and pray that netgear adopts a similar approach to their router software.
      • rhester72's avatar
        rhester72
        Virtuoso
        Don't assume your ping will double on the satellite.  My PS4 is hardwired into my satellite and I get 3ms RTT.
        Rodney
