dunkens's avatar
dunkens
Apprentice
Jan 16, 2019
How to get an RBS40 working with nighthawk rax120 ?
Hi   Is it possible to add and rbs40 to an rax120 router ? Want to use the rbs40 as an extender   How should it be setup in that case ? rbs40 is wired   the rbr40 is broken ,     ...
  • michaelkenward's avatar
    Jan 17, 2019
    dunkens wrote:
    Hi
    rbs40 is wired
    The RBS40 is a satellite. You need an Orbi hub to make it work.
