dunkens
Jan 16, 2019Apprentice
How to get an RBS40 working with nighthawk rax120 ?
Hi
Is it possible to add and rbs40 to an rax120 router ?
Want to use the rbs40 as an extender
How should it be setup in that case ?
rbs40 is wired
the rbr40 is broken ,
- Jan 17, 2019
dunkens wrote:
Hi
rbs40 is wired
The RBS40 is a satellite. You need an Orbi hub to make it work.
michaelkenward
Jan 17, 2019Guru - Experienced User
dunkens wrote:
Hi
rbs40 is wired
dunkens
Jan 17, 2019Apprentice
As the sat has been in the network eariler , cfg with the same wifi settings as the rax router it seems to work .......
the orbi sat is connected via wire to a diffrent part of the house , and there is full wifi coverage , if the sat is turned off it became a deadspot
and if i login to the sat i can see devices connected to it
Connected Devices
- FURRYe38Jan 18, 2019Guru - Experienced User
I have noticed that if the RBS is initially setup with a Orbi router, and you remove the Orbi router and replace it with a non Orbi router, leaving the RBS connected via LAN cable, the RBS seems to work well as a wired AP. I would presume that if the RBS was factory reset that it would need to be setup with the Orbi router again to make it work as the RBS doesn't have any settings in it's UI for configuration. It's configuration is automatic from the Orbi router.
Connected Devices
- dunkensJan 20, 2019Apprentice
Thnks , then its why its working as a ap :)
Then ill just keep the same settings and it should be alright :)
