SunriseMan
Aug 30, 2020Guide
How to get Orbi to pass through DNS information in DHCP?
I have an Orbi RBR50 running Firmware Version V2.5.1.16. I'm using its DHCP feature. The problem is that no matter what settings I try in the configuration, it always hands out client leases with the gateway address as the DHCP address.
I guess this works, if inefficiently, in many cases. But it's a real problem now that Microsoft is adding DNS over HTTPS capabilities to Windows. (It's already in the Insider previews, they'll be rolling it out in release versions in an update.) It automatically detects whether DNS servers can do DNS over HTTPS, which of course the router does not.
Is there a way to make the Orbi tell DHCP devices to use the DNS servers specified in the configuration? If not, it will become a major hindrance to security as DoH gets widely rolled out.
Most of NG routers don't allow for DNS proxy bypass. So you can set DNS on the router for any kind of DNS you want to use, however all clients will only get the routers IP address for there DNS entries.
- MstrbigMaster
SunriseMan wrote:I have an Orbi RBR50 running Firmware Version V2.5.1.16. I'm using its DHCP feature. The problem is that no matter what settings I try in the configuration, it always hands out client leases with the gateway address as the DHCP address.
The router's DNS server is an internal server. The Orbi uses the ISP or user provided 3rd party DNS servers, such as Google, Level 3, Open DNS, etc.. DNS over HTTPS server implementations are already available free of charge by some public DNS providers.
Mstrbig wrote:The router's DNS server is an internal server. The Orbi uses the ISP or user provided 3rd party DNS servers, such as Google, Level 3, Open DNS, etc.. DNS over HTTPS server implementations are already available free of charge by some public DNS providers.
That wasn't my question.
A DHCP server gives DNS addresses to devices. Orbi's DHCP server is broken and always gives the router's address as the DNS address. So my Windows computer thinks that the DNS address is 192.168.1.1, rather than the address I configured.
I use a service that supports DoH. But Windows (again, for now I'm talking about the Insider versions, but this will soon be true for release versions as well) detects that by just trying to do a DoH request. And that will always fail, because the Orbi doesn't support DoH.
I'm not expecting the Orbi to support DoH. But its DHCP server should be able to correctly pass along the correct DNS servers rather than incorrectly giving its own address.
- MstrbigMaster
SunriseMan wrote:That wasn't my question.
No I understood what you were saying. Most all home user routers are, as you stated, broken.
And I am currently on Windows 10 Preview Build 20201.
There's still a lot of debate over whether DoH is good or not, and I'm sure a lot will change before it is available in public versions of Windows 10.
Most people rely on DNS to block malware, enable parental controls, or filter the browser’s access to websites. When DoH is enabled, it bypasses the local DNS resolver and defeats these special policies.
- jayell1Initiate
I was trying to do the same thing to get a pihole to act as an intermediary DNS. I finally decided to let the pihole handle DHCP because it is better able to do that -- so I turned off DHCP on the Orbi and turned it on on the pihole -- now everything works great.
