RikParr73's avatar
RikParr73
How to open RTSP 554 on Orbi?
Hi
Trying to set up cloud storage for my CCTV, can't see option for port forwading in advanced settings for RTSP 554, am I looking in the wrong place? Searched around and can't see where.
Thanks in advance. Rik
  • FURRYe38's avatar
    What is the Mfr and model# of the IP modem the NG router is connected too?
    There may not be a preset for that port. Have you tried a manual configuration for Port Forwarding?
    Besure to disable uPnP if you set up a Manual Port Forward configuration...
    • RikParr73's avatar
      RikParr73
      Modem is a Virgin Media Superhub 2 (UK) I have tried manual port forward set up on RBR50. uPnP is disabled on Orbi. Superhub 2 is set to Modem and Orbi as router. For some reason unable to access modem GUI.
  • FURRYe38's avatar
    I would contact the Mfr of the CCTV and ask for additional help and information regarding this. They will have more information on how the CCTV should be configured. Might ask them if they have tested there products with wifi routers to see.
    Some modems when put into bridge mode, do allow for UI access anymore in that mode. You'd have to reset the modem back to defaults to re-gain access.
