paulcwr's avatar
paulcwr
Tutor
May 13, 2018
how to remotely reboot the satellite ?
How can I remotely reboot the satelite, either using the osx app or the web based management application?  I see on the web based application how to reboot the main router but not the satelite.
1 Reply
  • Login to the satellite's Web-IF and access the debug.htm page. Turn on telnet and login via telnet to that satellite and type
    reboot
    Not exactly from directly from the management interface, but better then going there and pressing the reset button or power cycle the unit. However, if you still can reach the satellites Web-IF, then rebooting it hardly isn't necessary, is it? The question is, why do you want to reboot the satellite, anyway?
