chrza
Feb 22, 2017Guide
How to see exact Wifi quality between RBK50 and RBS50 after installation?
Hi! I would like to see a feature where I can see the excact Wifi speed between the Orbi Router and satellite. While first installation the light was blue but I found that the speed isnt very good. ...
nsfw
Feb 26, 2017Aspirant
Not 100% sure this is helpful, but under Advanced-> Click the "Show Statistics" blue button
Look at the last line:
WLAN Backhaul
My status is:
1733M
Wonder if you move it closer or further if you see this number change. Could be an indication of how well you've placed your satelite.
loomis1975
Feb 26, 2017Luminary
I'm pretty sure we had the discussion about that number back in September. Pretty sure its just a label....Static.
- JMU1998Feb 26, 2017Luminary
Looks static mine says same. I truly wish someone at Netgear will wake up and unlock this machine's potential. ORBI is using a Qualcomm IPQ4019 which is a 720Mhz Quad core Processor!! Paired with 512Mb of RAM and 4Gb of flash and a wired backhaul can't be added via Firmware??? Seriously?? not even offer wired backhaul in AP mode?? Seems a massive waste of a powerful machine limiting it's potential because of poor Firmware features.
I have made the same statement on the currently ongoing Netgear idea exchange as well hopefully it gains traction.
https://community.netgear.com/t5/Idea-Exchange-For-Home/Netgear-Orbi-Wired-Sattelite/idi-p/1145210
